  • Replies 275
matts car was making some funny sounds.
turned out to be the turbo coming off.
tightened up, and fixed.
nice pool at the park we stayed at.
the cabin was a little small.
Cabin might have been a bit small but it was cheap :) And thanks again for fixing my turbo, was appreciated!
What an awesome trip. Thanks Luke and Scott for travelling with me and thanks again Scott for letting me drive your car; not an easy thing I know.
I've uploaded a few pics to Flickr: http://www.flickr.com/photos/82729085@N08/sets/72157638070125915/
And here is one of my Hillclimb runs: https://www.youtube.com/watch?v=e0kuVWpu_-s
That really was a narrow and steep track, was pretty worried about binning the car.
I have a couple of laps of Mallala uploading now.
It is hard to find food in wagga wagga at 8pm on a Monday :)
Try finding a room at midnight... :P
And you guys were travelling with no spares for the trailer? NUTS! We blew TWO tyres on the trailer on the way down. Luckily zero issues on the way home.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
