hey guys i thought this thread might be a good idea for some of us to post in.
basically i thought it would help if we put up places where we have seen speed cameras that we may not expect them or we rarely see them, so we can be carefull around certain areas we may have thought we'd be ok to have a blast in.
(note not speeding would be the best bet, but for most of us with the cars we have, the temptation is to great)
i guess i'll start, on drakeford drive heading out towards issabella plains i got busted by a cop car hiding in the bushes with a radar gun, i was doing about 150k in my lancer last yr and all of a sudden i saw them, i jammed on the brakes but only slowed down to 125 b4 they saw me, so they were well hidden as i only slowed down 25k with the brakes jammed on. they chased me down and kicked my ass heavily.
also there has been a speed van once or twice on the turn onto namatjira from hindmarsh dr. its a very random spot but if u hammer through the corner then u'll be almost certainly done.
feel free to add guys, i hope those 2 helped.
Yeah mate, good plan. I've recently moved back to my olds after breaking up with my girl, and have seen a speed van at the bottom of Kerrigan street in Fraser/Charnwood just before it goes into Dunlop (near Shakespeare Cres entrance) almost every morning on the way to work. You can really hammer down that street. Before the chicanes got put in, used to be able to get airborne!!
they park them on maribyrnong ave in kaleen a lot down near one of the primary schools. i've been caught by it once by surprise, i was only going 69 in a 60.
but at night i see them always parked behind signs on the side of the road trying to look inconspicuous. isn't there a law or something that says they have to be visable to a certain extent? hiding behind signs or in bushes is hardly visable
well, if any of u live in the Kambah area, be careful on Livingston Avenue (the one that goes past the Kambah Pizza/Takeaway place)....
I go that way cos it's quicker than Athlon when there's lot's of traffic, and it joins Sulwood at the top...but the white van has been there a few times :P
Coming home from the city, I was going down the Parkway, I hit the straight stretch from just past the zoo to the Curtin turn-off, and just past that turnoff in the bush was the gold/purple ford cop car. He has perfect veiw of over a kilometre of straight road. That twice now he has been there at bout 11pm onward on a weeknight.
Luckily I was in my daily driver, [suzuki sierra] and was just cruising on the limit, becuase you dont notice him until your smack infront of him, even with your highbeams on, with the angle of the incline its difficult.
If you're taking the backroad that goes between Lyons & Weston, it's probably not a wise action to come flying up the hill (coming towards Weston)....more often than not, just as I come over the crest of the hill there's a camera van sitting right under the parkway overpass.
that's some good info, i regularly drive north on the parkway to belco at that time, i'll make sure i'm right on 100 as i come to the underpass. sometimes down the hill it sneaks up to 110 - 120 without me noticing
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
