Wrecking r33 Gtr vspec
Midnight purple
Everything available
Rb26dett engine from a r33 Gtr vspec, motor has done approximently 10000kms. I have pictures of recent cold/dry compression test and videos of the engine running can send or show to serious buyers only.
**Can fit and install for extra by mechanic locally on the Gold Coast pm for details**
Compression 160-165psi across the board
Bottom end
R33 Gtr crank
N1 block
Cp pistons and rings
Eagle rods with arp rod bolts
Arp mains
Arp head studs
Greddy oil pump
N1 water pump
Tomei oil restrictor
ATI balancer
Top end
Tomei Poncams 260deg 9.15 lift in and ex
Greddy cam gears
Head full recoed etc
Brand new rocker cover seals and half moon seals
Painted r34 Gtr red covers
Price $9500
Depending on buyers can include standard injectors and turbos for extra
An also supply hks gtss turbos, sard 800cc injectors and power FC Ecu for extra
R33 Gtr brembo brakes and rotors
Front and rear
Great condition
$1500
R33 Gtr rear seat
Great condition
$180
R33 Gtr door cards
Front and rear in great condition
$300
R33 Gtr bonnet
Great condition
$600
R33 r32 Gtr power FC and hand controller
Great condition
$750
Sard 800cc injectors for rb26
Great condition
$500
Hks complete suction kit with hks pods
Includes inlet and outlet pipes
All hot side piping
Great condition
$650
Hks Intercooler hard piping kit
Great condition
$280
R33 nismo Gtr speedo cluster in black 320km 11000rpm
Great condition
$480
R33 gtr fujitsubo cat back exhaust with cat
$250
Rb26dett fujitsubo tuned length front pipe
$150
Hks gtss turbos
Great condition
Only ever run on 15psi
$1600 turbo and actuators
$1700 full hot side
R33 Gtr engine wiring loom
$180
Blitz boost controller sbc I-d
New model with the little screen
$250
Blitz power meter I-d
New model with screen
Matching to above
$200
Gtr boot no wing
$90
R33 Gtr drivers window switch
$80
R33 Gtr drivers side window reg and motor
$60
R33 Gtr centre gauges
$90
R33 Gtr v spec diff
$200
R33 Gtr rear 6 bolt shafts
$100 each
R33 Gtr rear hubs with hand brake assembly
$190
R33 Gtr v spec rear bracing under subframe
$90
R33 Gtr v spec bracing that goes under front of gearbox
$80
R33 Gtr abs unit
Great condition
$180
R33 Gtr rear bar
Midnight purple great condition
$90
R33 Gtr front reo bar
Great condition
$100
R33 Gtr spacers for front guards
$60
R33 Gtr genuine front strut brace
$70
R33 Gtr genuine rear strut brace
$70
R33 Gtr boot brace
$60
R33 Gtr ignition barrel and locks
With key
$150
R33 Gtr steering wheel and air bag red stitching
$150
R33 Gtr master bm57
$190
R33 Gtr clutch master
$70
R33 Gtr drivers headlight
Great condition but has 2 broken mounts for grill
$100
R33 Gtr dash
$60
R33 Gtr surround with hazard lights etc
$60
R33 Gtr front drive shafts
$80 ea
R33 Gtr boot trim
$80
R33 gtr radiator
$70
R33 Gtr bovs with recirc stuff
Complete set up
$180
R33 Gtr Intercooler
$100
R33 Gtr bonnet latch
$30
May have missed stuff let me know what your after
Gold Coast Nerang
0487924497 or 0414596256
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
