Can Anyone Think Of A Way To Lubricate A Turbocharger Shaft With No Oil Supply? Serious Question
Ready to be flamed for the odd, unrelated question...
But I had no idea what section I should post this in, but this is a very odd yet serious question.
Im using the centre cartridge, turbine wheel and turbine housing from an old turbo for a project not really related to engines/ cars etc. The turbine wheel will not be exposed to heat levels as high as it would straight out of the motor, and I dare say it would be spinning considerably slower. No compressor wheel/housing.
There is no real way to plumb oil or water coolant lines to the turbine without spending a considerable amount of time / money.
Can anyone think of a way to keep the turbo from breaking? I have no real serious knowledge about lubrication systems, but could a high temp bearing grease be used perhaps?
Any info or ideas would be appreciated...
If it still has the centre then plug the oil holes and fill it with engine oil, or pump it full of grease like you suggested, which may be the better option
Grease may be to thick I am thinking now that I start to use my brain a bit. Perhaps pumping it full of engine oil, with a small sump fixed to turbo for it to feed in and out of could work. The oil wouldnt be going through a motor, so it would last longer? The sump could have a drain and fill for servicing...
Someone tell me why this wont work before I waste money.
Why don't you elaborate more on the project, then we could get an idea of what would be required from the lubricant?
The fact it's not exposed to a large amount of heat or RPM may mean you could get away with a thinner oil and therefore less friction / more efficient rotation. You may not even have a need for a sump, but more details on the project would help with recommendations.
Is this a DIY turbojet or something? If you are keeping the turbo stationary, a gravity fed oil drip would do the trick, otherwise a small 12v pump would supply plenty of oil. Dont use grease....
Look at what the manufacturer of the turbo specifies.
Look at what the turbo was originally fitted to.
Also, Lubrication of shaft hehe.
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
    • Sequential Is fine to drive on the street
