  • Replies 40
I think some NSW folks are going a bit silly with the unprovocted misguided malalligned humour.
MODS:
HKS Turbocharger
How powerful u guyz think this is?
I dont realy get it ? why does this bloke get both barrels for ? he just posted his car in the wrong section i spose ... ohhh hang on this is NSW section ahhh forgot about that ... ahh well that explains it then hehe .... so was it an HKST51R under the hood too push the limit of mods too 1000kw...?
Well Im going for the 250kw mark bue too my self having a HKS 3037s under the hood and thats good for around 500ps so im seeing that this turbo is good for just under 400ps so yeh i reckon around the 250kw mark on about 18 psi .But seeing he has got the pump but no reg i dont reckon the injectors could hold the fuel up to it .... so around 230kw....
No probs red900ss :)
Yea its 230Kw but it still has more power to come. Im running 16psi boost and i got told that i can run the turbo in the 20's to kick the power closer to 270 Kw. Just need to buy a Apexi AVC-R.
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
