I'm running 272deg 9mm lift camtech cams with a GTX3076r. 300rwkw on 15psi. High quality parts, no complaints here what soever. No VCT here. Can't recall if the 268degs were out with VCT support when I bought mine or not.
Edited by Reflector
bottom to mid is what will be affected by vct. interested to know...
Reflector: post up a dyno graph if you have one
This is without the cams degree'd (currently doing it now - Cars off the road).
Running 14-15psi through an Apexi-AVCR however we're ditching that as the boost controller in the future and using the Link G4 to control the boost. Going to put 18psi through mid range and bleed off to 15psi. Once I get some spare dollars I'll rebuild the bottom end and then the fun begins. In regards to driveability, it's a kitten down low, drives perfectly, put your foot down and it's a lot of fun - need some stickier tyres haha ;). This set up was built with 1/4 mile in mind as well. We had to put limitations (cuts) at redline (7500rpm) as it wanted to keep making power above and beyond but with a stock bottom end, there's not point pushing it.
Edited by Reflector
Thats a nice linear power curve. Looks like mine. We hadto put limitations aswell on my car (7650) for some reason the power doesnt taper off. Never opened up my engine after buying it off a member here so im unsure if the heads had some sexying up or what. I can drive mine all day when cruising but when she's open everybody hears it
Thanks man. I copped a lot of negative responses when stating I wanted to ditch VCT. In all honesty, I'd be interested to see the difference with the same set up with VCT enabled (guess smaller inlet cam with VCT support) but these RB engines really perform beautifully from 3000rpm onwards. It all depends on what your goals are.
Question is, what are you hoping to achieve? More response, more low down torque, more top end power? What other supporting mods do you currently have?
Camtech are a good choice regardless, great customer service and their products are high quality.
Edited by Reflector
Well currently im making 300kw. Tomei fuel pump greddy plenum 3076 .82 with a tial 44mm gate straight through 3 inch exhaust power fc. The usual stuff. Im putting hks 256/264 cams with a hks ex cam gear. Tomei springs. Nismo 740cc injectors. Nismo thermostat. Nismo reg. Iv recently just finished my 044 and surge tank setup. Just spoke to the guy who's tuning it. Im upping the boost to 20 to 22psi. Aiming for 330 plus kw. I use the car for drift and street driving. But I want to break into the 11s and run a 120mph pass. So basically my car will be an all rounder.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
