Mugabetown - Whoretownin' At It's Worst.
Welp, Its raining here in Vancouver today, not surprising i guess.
Vancouver is a very, very nice city. they've really done a lot right with regards to their transport and urban planning, even staying 45km from the CBD its easy to get around. Biggest downside is that they drive on the wrong side of the road, i have to keep making sure i don't get run over crossing it by looking the wrong way.
  • Like 1
So just in vancouver they drive in the wrong side of the road? Becuase every where else is the same as us right?
Pretty sure only America and Canada drive on different side of road to us.
Australia, japan, England and South africa are pretty much the only countries that drive on the left hand side of the road, everywhere else drives on the other (wrong :yucky: ) side. I was just poking fun.
lots of places drive on the right. All of Europe for example. You are correct about Canada though. Shows how good my memory is. So all the skylines over there must be converted!?
Morning all.
Yep. Matt got banned for something silly which even I don't understand
neither do I.
thats why im questioning it.
I dont think its right as there were no personal attacks, no trolling, and no baiting.
still waiting to hear a more definite answer.
Seriously....He didn't make reference to anyones mother, sister, hot swedish cousin?
You have a hot Swedish cousin? Dibs.... If its a female and over the age of 18 but under the age of 25
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
    • Have you done 10x restarts since it came on?
