Mugabetown - Whoretownin' At It's Worst.
Cool, I keep half thinking about going single on my car, but then think I really want to stay with twins even though the single seems like the better idea. Bah that's a while off in any case.
do eeeetttt!!!!!!!!! go single bunts, go nutz!
With twins I can keep the stock look though, which in this day and age is ever more important, I am putting the stock air box back on my car at the moment, cant do that with a high mount!
Its a pretty big move
check out Piggaz car in the precision thread!
Love his R33... such a weapon
yeah, his car is crazy for just having low mounts. having said its a 2.8ltr and head work is crazy and his setup works extremely well.
however going through almost a full tank of petrol after 100km is not so attractive to me
  • Like 1
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
