Mugabetown - Whoretownin' At It's Worst.
Just went out to the shed to get the skyline out to wash it and take it for a drive and the battery is flat. The trickle charger sh*t itself sometime over the past 3 weeks
next time take the battery out!
Disagree. Dirt, dirt cheap, gets you anywhere, not the worst on fuel.
LOL! worst daily choice ever is an old Falcon
For a carton of xxxx and a bottle of scotch can't really go wrong, ac is cold and it uses half as much fuel as the abomination, also means I can start bying parts
Only because the abomination is a thirsty POS.
  • Like 1
Question... who has had a screamer pipe before? Ive always been against it due to driving my car a lot and it would be annoying. Now i wont be driving my car anywhere near as much im contemplating getting one for something different. As far as im aware there is no increase in performance having one..
i have had one, they are loud and if you have a tiny turbo/internal gate, just no.
in that example, sure.
when the dump pipe is fabricated get them to make a section that can unbolt so you can seal up the exhaust and have it as a screamer but also gives you the option to plumb it back with relative ease.
some people love them forever, some people like them for a bit and then just want it to shut up.
