Mugabetown - Whoretownin' At It's Worst.
Just went out to the shed to get the skyline out to wash it and take it for a drive and the battery is flat. The trickle charger sh*t itself sometime over the past 3 weeks
next time take the battery out!
Disagree. Dirt, dirt cheap, gets you anywhere, not the worst on fuel.
LOL! worst daily choice ever is an old Falcon
For a carton of xxxx and a bottle of scotch can't really go wrong, ac is cold and it uses half as much fuel as the abomination, also means I can start bying parts
Only because the abomination is a thirsty POS.
  • Like 1
Question... who has had a screamer pipe before? Ive always been against it due to driving my car a lot and it would be annoying. Now i wont be driving my car anywhere near as much im contemplating getting one for something different. As far as im aware there is no increase in performance having one..
i have had one, they are loud and if you have a tiny turbo/internal gate, just no.
in that example, sure.
when the dump pipe is fabricated get them to make a section that can unbolt so you can seal up the exhaust and have it as a screamer but also gives you the option to plumb it back with relative ease.
some people love them forever, some people like them for a bit and then just want it to shut up.
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
