Mugabetown - Whoretownin' At It's Worst.
Indeed I did.....still wouldnt drive it by choice. but for the price...i guess you cant argue. would still go for the Hatsu or similar small FWD cheapness instead. I miss my Madaz i find this hard to Believe. But then P platers are pretty bad at driving :) I assume you mean newer? to me an old car has a Carby :thumbsup: night Ants, hope to see it out and about soon.
lol yep. Meant 5 years newer. Yeah hopefully the car will be ready this week :)
Morning all, T minus 59 mins and counting to tooth extraction....
Why? The mazda makes a few kw more and the same torque and is only a smidge heavier. It also has no lag. Which I think was the deciding factor.
sorry I read Mk.V.
correct, but P platers still suck at driving :)
That sucks major balls! I hated having my wisdom teeth removed, mine hurt like a bitch mind you I had two done in the chair and heard them cracking them off my jawbone and the other two they put me to sleep for and apparently I was trying to talk to the nurse about my car whilst the surgeon was trying to get my teeth out, I also woke up to find a piece of paper which I had scrawled my blood pressure on at different readings - The nurses found it entertaining, still have no idea how I got a piece of paper and a highlighter *scratches head* my recovery sucked took close to 2 months in total waa!
And morning everyone, happy (or not so happy) Monday... Came to a great realisation this morning that I can watch Initial D on youtube whilst on the cardio equipment at the gym - That was a good start to the day :)
Oh that does sound bad, I had my wisdom teeth out (and had two extra for a total of 6 :0 ) but my surgeon was awesome, i was alright in 4 days, had them out on Monday and played rugby on the Sunday with no issues. I was pretty weird recovering from anesthetic too. I woke up, unplugged my heart monitor and pulled out my iv and took my self for a bit of a walk, I was half way down the hall to the elevators before they worked out where I went!
dentist appointment tomorrow, hopefully i don't get any bad news about mine. One sort of started to poke through in the last few years, but then stopped.
Hopefull you have adequate private health cover for this because dentist = mega cost
Just rang TNT maybe it won't arrive today... Really getting annoyed about this process
welcome to my world........................were everything appears to be so slow that I feel like Flash Gordon sometimes by comparison
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
