Mugabetown - Whoretownin' At It's Worst.
I'm at work, work is boring and through photosynthesis I am boring as well....
I am not convinced that is the correct use of photosynthesis.
I don't think think using radiant energy to turn carbon dioxide and water into carbohydrate is the cause of your being boring. Though according to Ants you are green so maybe you do photosynthesise
I hate everyone having breakfast and days off... Stupid me even said yeah no worries I will do a full day Saturday before working Saturday night at my other job, that's what I get for agreeing to shit when I am having a good day!
LOLZ
4th fishies down the freeway! ensure to upload vid for lolz
2nd half throttle slide off a round about and up the street (couldn't hit the hammer due to traffic) he went very quiet
What are u on about, photosynthesis is the process of photographing synthesisers in your spare time.
How could you not know that, youre a sound engineer you deal with this stuff every day... And twice on weekends when you photograph your German folk band zeig mir die Müsik
  • Like 1
bahahahahahahahha!
Quick snap shot from Zeig Mir Die Müsiks last gig they played at keine krähte hier arena in woodford, not bunts well developed beard (it's a fake of course but no one needs to know he can't grow facial hair)
I spoke to Sean this morning.
The Ant-Eater went back on the dyno - everything going well
An hour after being on the dyno - Hatlech decides to shit itself
:( aww not good bro
Alledgedly everything is still running but the USB port slows down and Sean cant get any proper reading from it.
Haltech was sent back to Sydney yesterday (hopefully will get it soon) to have a look at it.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
