Mugabetown - Whoretownin' At It's Worst.
yeah it sure does sux dogs balls Mel.
But that at least its with them. Worst case scenario is that is fubared and will have to get a replacement one.
Only problem is I highly doubt its under any warranty period so the replacement one will most likely be forked out of my own pocket and any tuning that Sean has done will be gone (unless he can just reload any maps he saved which I think he would)
Mega suckiness right now.
Also feel demoativated
Do you still have your power FC? Maybe use that till the halt each is back?
funny you say that. I had actually said to myself that I would hold on to the PFC until I know that the car would be running with the Haltech.
After speaking with Sean (three weeks ago) he told me everything was runing fine with the Haltech and car had already went on the dyno, so I decided to sell the PFC.
Was sold the week following
If only I knew that my ECU would shit itself during a dyno run then I would of kept it. But im no clairvoyant
Worst thing about my no motivation is that I have a night ahead of me still, bring on about 10:30pmish!!!!
Me either Melly, think I'm guna give myself an early mark today. Need to play me some more GTA V
Wish I could go on strike, or leave early... But I am not going anywhere until the boss is back and gives me my cash moneys for being the wonderful person I am and agreeing to work tomorrow... *sigh*
that does not sound very cool either. I should not be really complaining.
there are others in much worse situations thats for sure.
should be thankful for what we have.
That's for sure - I was going to say I am still in a good mood despite no motivation and want to go home and sleep, then I spoke to soon, some people are dicks... :verymad: You know those people that always think they are right no matter how wrong they are.... Just had a call from one of those people, I want to stab him in the eye... :happy:
Really sucks ants. On the other hand, you have great things to look forward to in other aspects of life.
exactly mate. Im also happy to know a good bunch from people here so thanks to all you guys.
especially to one member from SAU who has been giving me great support lately (you know who you are) and of course my wondeful wife who has seen me being more emotional then her of late and she is 40 weeks pregos
going from bad to serial killer angry there Mel. Although I can relate to a certain degree....................this world is unfortunately also filled of stupid retards
Haha Natural selection isn't very efficient sometimes :no: It's ok I won't really kill them, I might just play the sims, build a pool, send them for a swim then delete the ladder... :yes: Unfortunately common sense is not very common!
lol........re sims. The evil is comin outa ya Mel :devil:
He saves his tunes so if you get another haltech you will be ok!
I took some timing out of my car, runs ok now, no knocking!
that's good to hear Bunts. Now you be a good lad and let Sean tune my car before you drive yours there :P
I maintain it's because my mum always told me in-case of emergency stab people with my stilettos to get out first... :teehee: We have it all planned, she becomes an assassin and I become the get away driver... :devil:
Luckily I can control my temper to a certain degree I more just get really angry and have a hissy fit and occasionally break something like a pencil or a hairbrush then feel bad I broke said object :) I would loose my shit at someone but never hurt them intentionally unless it was in self defense! :thumbsup:
I am not planning on going there for a few weeks yet, Gave it a good kicking last night around the hills, no issues, doesnt seem to have lost power, winning! however I am still looking forward to being able to turn the wick right up
Edited by Bunta
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
