Mugabetown - Whoretownin' At It's Worst.
That awkward moment you need to get something out of the bottom drawer for a potential client whilst wearing a skirt and they stand behind you the... whole... time... Then decide they need something else from there... *Bitchslaps seedy old man*
you are on a roll Mel. lol.....
Winning.
They will be a client now haha
^ this
Hey if it sells houses! He wes extremely seedy tho I don't know how long I could handle dealing with im if he goes ahead...
So you are commission based also? Epic old man win :D
Something about hating what you have to do for money Melly??? hahahaha
Lol I know, I am on a fantastic roll here... Just FYI I sell houses, push paper, fully legal, clean, non sexual stuff...
^ this
Shhh you!
Shhh you!
sssssscccchhhhwwweeeeetttttttttttttttt!!!! a REP!
Nah no comission unfortunately but I get kickass end of year xmas stuff this year they are sending me swimming with sharks and two other xmas parties all paid for :)
sending you to swim with Sharks :dry: eh!
kinda tells me they wanna get rida ya :devil:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
