Mugabetown - Whoretownin' At It's Worst.
I have seen with my own 2 eyes a stock one do a 13.2 something and one with a decent clutch and a ECU do well into the 12s.
Those times are....not good. And knowing Chris in particular the launch would have been a softie.
Oh I know it can be done... What I'm implying is that anyone with half a mind wouldn't do it to their car.
They could do a 6 second pass, won't change the fact that I broke 2 of them and think they're weak as piss droney horrible sounding boost fed midget motors
How do you break a N/A 25? You are menat to use oil not sand! How many times must I tell you!
  • Like 1
ls1 shits on rb25. just saying. ive had both.
no idea how or why they are being compared.
but i was an import guy since i could drive. (15 years) first manual ls1 i drove i bought. sold 33.
200kw rb vs 225kw ls1.
ls1 was much more fun to drive.
awaits butthurt, flames, and accusations of being a nick sympathiser!
We thought people with half minds wouldn't put a LS in their skyline either...but here we are! :P
If you aren't launching a GTR hard (near the limiter) dont bother, they are not a fast car off the mark unless you launch hell out of it
Fastest unopened, standard injector ls1 is?
Fastest unopened, standard injector rb is?
Fastest unopened, standard injector vg is? 11.76 @117.91
Who cares don't be a scab and change ur injectors lol.
In saying that depending on what u class as unopened there are LOTS of cam only ls1s into the 11s
I stopped listening after here, I saw something about hell.... Do u want to repent your sins Andrew come on, repent embrace, love
Unopened is unopened ;)
Stock turbo also ;) Why change injectors when stock can net 11's? haha
Dirt Garage ran an 11.8 unopened and with stock injectors, thats just off the top of my head
now is not the time to repent, I will only have to do it again later
So what ur saying is, it's ok for your motor to change something to allow much more air into the engine but it's not ok in my case.... Hmm
Yer but the sooner the better u try repenting all your sins when your 90, you'll be repenting for shit you didn't even do.... "I'm sorry for digging up the lawn.... Oh that I was the dog, I hated that dog I distinctly remember the day I got him a Sunday I believe or was it no no it was a Wednesday cause it was the same week as aunt Betsy, or was it carols birthday, aunt carol was such a nice old.... Old, old? Old spice I love the smell of that. Wait what was I talking about"
See how we will run into an issue, repent now while u can
Just be happy that you have the fastest auto Ls1 R33 that is black and orange/red owned by a guy called Nick from a town called Gatton.
thats the thing about repenting, doesn't matter if you did it or not, all is forgiven.
No.... If u haven't noticed I'm never happy unless I'm annoying someone else
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
