Mugabetown - Whoretownin' At It's Worst.
Northsiders, Westsiders, Insiders,..............................really dont care which country your from from or what state your from as long as your a sensible individual that works for me.
He knows he is important, without him it's one less person to drink beer with seriously, I don't even drink beer and don't know how I could handle that...
you just keep getting funnier and funnier................
I'm going to take an uneducated guess and say all the Eskimos that ever existed are in here
Oh yeah, I think that signage makes it educated tho...
Or braver and braver... Depends on how you look at it lol
You didn't mention eastsiders or outsiders...
if we were sensible we wouldn't be here!
Ah crap :(
Also *you're
salt, with blended vegetable oil and butter milk
Kinda cheating by having butter milk in there :dry:
A:Hey is there any peanuts in this soup
B: oh no sir
A: eats soup (dies)
B: but there is peanut oil muhahaha :devil:
Why is Tony black?
Why does Melly wear short skirts?
Why did Nick ls1?
Answer them all correctly for all the internet points.
Ever.
Genetics, Ancestors copped too much sun
Because she can
Because he is a Bogan from Gatton
B: oh no sir
A: eats soup (dies)
I cant beleive its NOT butter,
Oh it isnt, it is just 80% the same including the main ingredients
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
