Mugabetown - Whoretownin' At It's Worst.
Northsiders, Westsiders, Insiders,..............................really dont care which country your from from or what state your from as long as your a sensible individual that works for me.
He knows he is important, without him it's one less person to drink beer with seriously, I don't even drink beer and don't know how I could handle that...
you just keep getting funnier and funnier................
I'm going to take an uneducated guess and say all the Eskimos that ever existed are in here
Oh yeah, I think that signage makes it educated tho...
Or braver and braver... Depends on how you look at it lol
You didn't mention eastsiders or outsiders...
if we were sensible we wouldn't be here!
Ah crap :(
Also *you're
salt, with blended vegetable oil and butter milk
Kinda cheating by having butter milk in there :dry:
A:Hey is there any peanuts in this soup
B: oh no sir
A: eats soup (dies)
B: but there is peanut oil muhahaha :devil:
Why is Tony black?
Why does Melly wear short skirts?
Why did Nick ls1?
Answer them all correctly for all the internet points.
Ever.
Genetics, Ancestors copped too much sun
Because she can
Because he is a Bogan from Gatton
B: oh no sir
A: eats soup (dies)
I cant beleive its NOT butter,
Oh it isnt, it is just 80% the same including the main ingredients
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
