Mugabetown - Whoretownin' At It's Worst.
Because they are waaaaay to big.
You won't get any shit from me about ls1 in a skyrine Nick. Living it Gayton tho, that's another story.
A mate had a NA zed, spent many, many thousands doing a vh45 conversion (and 2 years). Sounded awesome but was still slow. So he pulled that out and went vgTT. Cheaper and faster.
Since parted it out and is now talking m3CSL or lotus
Edited by MagicMikeZ32
That actually makes sense, but why not a more modern Nissan v8 engine?
They don't lope around like cammed up LS's do.
And the other reason was I just simply didn't want one, I don't know anything about the motors whereas info on ls building is plenty full and parts are cheap.
And to me nothing sounds better than a big cube natro v8 screaming up near the redline or shaking around at idle :jizz:
Haha aww but mike it's no fun unless it annoys people lol.
And that's the other thing the quad cams are massive same as with the 5.4 boss motors in falcoons
What about cost and time taken to make swap though?
Yep same idea as old bud that did the 1uz swap into a supra. He came to a happy laps with us once and the thing sounded sooo tuff like an f1 v8 mix. So I was naturally a little hesitant of lining him up, but when play time was over and I got a run down the straight with him I had about 3 1/2 car lengths over the start finish line and mines dead stock apart from the exhaust and the built box
Vh41 old Indy car engines :) methanol nom nom nom :)
Up near redline at 4500rpm lol
Yeah mates vh45 had extractors (custom so they fit lol) and exhaust and nistune and it would've had about 200rwkw.
Took about 6 months start to finish which I didn't mind cause I was on my ps still anyway and I'd just blown up my gearbox so the car was just sitting there.
Cost wise, it's only money... And the attention it gets and the "WTF is in that thing" reaction when people hear it fire up is just priceless.
Yer mines just got a custom extractors a crappy mail mafless order tune and basically a 3inch straight pipe and a dirty pod filter sucking like a 2 dollar whore off the intake pipe lol. Through my auto with the bigger stall I'd imagine id only have about 200rwkw....
For now
You still running stock cams Nick?
A friend of friend had massive cams in his. Was so bad that in top gear on highway at 110 he got chopped by a stock telstar lol
Top gear roll ons of course ;)
For now
optimism my boy. youll hvae 180 if your lucky. you need a tune!!!!!
Yer stock everything man, the motor in this trims days are numbered ;)
It's to fast to only have 180, I was chopping cars up around the 230-240kwkw mark at the drags
youve lost a lot of weight in that engine. plus you have more torque, that engine will be running like shit with a mail order tune and your bolt ons.... i have the hsv ls1, standard cats tho, with otr and full tune and that only cranks 230 atw.... manual.
alright maybe you have 190....
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
