Mugabetown - Whoretownin' At It's Worst.
Shit Mel that's full on. I'm sorry to hear that, warfarin is not fun, but then again I suppose clots forming is much much worse.
It's all good, learn to deal with it - Poor Zane had to deal with me when we found out I had the clot and he is the one that has to give me the injections because I am shitscared of needles
Full credit to him. I bloody hate needles. I faint every bloody time and I know this sounds pathetic too!
The nurse tried to teach me and I bawled my eyes out and tried to climb the wall to get away basically, a nurse friend up here showed him how to do it along with trusty youtube vids and he is ok now other than he hates doing it because I hate them
Yeah but legit all out of my price range :/ I went on a mass spending spree the last couple of weeks and got no money left haha I got about 500 saved up and only get like 400 from insurance :(
That's commitment.
You'd have to be careful with injuries too then?
Why don't you just drive it for now?? It's a car and manual
What she said...
That's commitment.
Yeahp sure do - Doctors initially thought it was a strained muscle but I pushed the point that is wasn't and then they found the clot, my hospital Doc that pushed to get all the tests for me was like Dr Nick off the simpsons, great doctor tho!
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
