Mugabetown - Whoretownin' At It's Worst.
Kids these days, cant handle thier booze! Just start earlier pass out at 9 still have 8 hours or more sleep.
I went hard from like 11-4 then slept til 6 this morning haha
I was 22-24. Was heaps of fun.
I did similar 19-21 but usually I would get home have a shower and straight to work, and that was without alcohol because I was always driving just didn't sleep and lived off redbull and mars bars...
When I was 22 I would work for 7.25 hours somewhere between the hours and 6 and 6 which I chose then go and do all the things you described the working lots and the no sleep is the part that sounded pretty shit to me!
Engine out.
Morning! That baby better hurry up. You don't want it arriving the day you get your car back!
have been thinking that everything will come at once........................thats usually how it goes.
So found out today, that seedy Sunday sesh' are not a good idea
well you get learn......................I have no doubt in my mind you will somehow learn this the hard way :P
Think there's something wrong with my radiator. We filled the radiator and reservoir up on Saturday, checked it Sunday arvo and the reservoir was empty. Curious..
was the engine getting hotter than usual?
Could have been an air pocket
most likely this ^
Eh, temp gauge was a little high yesterday and when i pulled up I saw it was leaking. It's all good, to the falcoon
fix if fix fix it fix it fix fix fix it fix it rb it fix fix fix it fix it fix it
you know u want too :nyaanyaa:
Its hard separating the good info from the bullshit, and then figuring out how it will effect stock prices but I guess I'm a step ahead of any other industry
Day trading is pretty hard, if you were to keep shares longer its a bit easier to win but the gains are less (mostly) so you would need more capital
Nah, buy in whole hog on the Skyline day/night market - guaranteed never to get all your money back... But the thrill of the buy and long term investment is worthwhile :) [disclaimer - don't take my fin advice] lol
lol @ disclaimer - so lawyer mentality
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
