Mugabetown - Whoretownin' At It's Worst.
The only person who knows what is going on is Sean. At the end of the day, he is a great tuner and hence why we have him on as a sponsor. He has a great deal of knowledge with these motors and also has a number of supporters. A lot of the people that use him speak greatly of what he does. However, not everyone uses him and anyone that has either built a car or required a major re-tune will tell you that these things take a lot of time.
I can appreciate that it is difficult from your end as you just want your car back. Although it's been 3 weeks since you delivered it to Sean, there has been a few things that have come up in that time.
1) the fuel pump
2) he fell ill for a week
3) Jambo - a massive marketing opportunity for him that probably results in a lot of revenue for his business
4) the ECU
The added difficulty is when you have people who haven't built a car before asking why it hasn't been done yet. You've got a brand new engine which is worth some decent coin along with some very nice go-fast bits, you don't want this rushed and botched.
My 2c, speak to Sean and try and maintain a positive frame of mind. :) I know that it isn't easy, but that's what you need to do.
Bunta and Colin had theirs tuned there and they were both quite nice and white and 32s and GT-Rs.... Creepy :P
Tony, hiscar has been there 6 weeks, not 3
My bad! Misread that as September. Either way, the best thing to do would be to discuss it with Sean in person. At this stage, other people asking questions could simply aggravate the situation.
Definitely my bad though!
Indeed :verymad:
exactly. It really makes u think how twice how they do business.........No such thing as good business ethics within this industry
There is you just have to get a mechanic that won't lie to you
Like... GST or total revenue, or Director's salary right? ;)
no. only if the transaction(s) in question is = or > 5% of the benchmark and also if the item is material by nature.........
majority of publicly and non-publicly listed corporations don't like it either.
Lucky for them I'm not an auditor........
LOL! Damn accountants following legislation. My accountant is also like that.
So martins car is back from the auto elecies.
Hopefully Tomorrow Jamie will give him a call and discuss what is being done and give him a quote, if we don't have a flat out day still have cars left over from Monday :/ why do hilux's have to be so crap
becauseToyota
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
