Mugabetown - Whoretownin' At It's Worst.
I see him trawling this thread as we speak :yes:
Interested to see what results we all get. There is another guy on here that just got his results back on a very very similar setup to what mine is. It made 480rwkw's on 27psi. 6466 with .84
Was he running E85?
Yep..
Here is all is....
That was my car.
Couldn't go past 27 due to needing to up the breathers on the rocker covers and mainly from frying tyres on the dyno
My main thing was that i wanted it be strictly streetable and wasnt fussed about the dyno figure - not that its too bad at all! Therefore I went for a 6466 with .84 twin scroll - I was concerned this would be too big as I was thinking to go for a 6266 originally - although very happy with this setup which is super responsive compared to most cars I have been in, not to mention torquey-as down low due to the RB30.
It has been running for some time on 13psi run in tune which it did 308rwkw on pump 98 - then 20psi on e85 which it did 365rwkw for about 2 weeks.
Even on 20 psi the car is a wild drive on the streets - stepping out in 4th gear once is hits about 4000rpm as if it was second gear (still waiting on half decent tyres to show up).
If I upgrade the catch can (which is small as I wanted it to be hidden) they could push 34psi but doubt I will ever need to, nor bother going to the troubble as this thing has been in the making for over a year now!
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
    • Nice, that's not laggy swtching between functions at all. Could it be less laggy than the factory one below? 😋
    • The 400R sold all 1000 units and 100 of the limited model so I'd say even if they just sold the GT with a manual it'd sell out in Japan for sure. I say 'sell out' because like the 400R I'm certain that Nissan JP will only offer it in limited numbers, or even in 150 unit increments like Toyota did with the GR Corolla (and sold them by lottery which I was denied 2 times, so gave up...)
