Mugabetown - Whoretownin' At It's Worst.
Yet the wedge still chops the a-bomb
Since Nick isnt here I will reply for him. The A bomb ran a faster quarter and if even if the wedge is faster from a roll on its only faster *Mysterious music*......for now
Haha this kid knows me well lol
This may be true but has Martin spent as much money as nick has on the wedge?
It would be pretty close, Both have had a engine swap, Nick would have spent more on the gearbox, Martin would have spent more on the turbo, computer ect
McFly can just up the boost in the Wedge though. What can Nick do?
Nothing and this is why martins car will always be faster than mine and he definetly should kill me down qrs main straight with roll on power of the rb
I am not defending Nick. I am simply stating Nick and Martin have likely spent similar money. And no it isn't always as simple as turning up the boost and pissing power.
Mines owes me about 25k totall including purchase
I didn't mean it like that but yeah. My main qualm with natros, especially high comp natros is that there isn't anywhere furthe that you can go. :(
Has anyone gone spastic on a natro vg motor?
I know there's one that races modified production that's fairly quick and they have a lot of restrictions
A couple, but not many. Was talk of a crazy one in the US but no results. Most basic Aus builds hover around 150rwkw. Not surprising really when a stock TT makes ~180rwkw. And you can buy them for about $2, and they drop right in.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
