Mugabetown - Whoretownin' At It's Worst.
He can't afford them but he'll get them, he's 22 still lives at home and gets his girlfriends to pay for EVERYTHING.
He just ordered a set of 18x13 -28 work Meisters, cost him something like 4k :O
.... Mayb he sells drugs
steal his GF.........problem solved!
  • Like 1
So, it's that time that comes every two years. Time to look at new phones. These are work phones and I've finally managed to convince the boss that maybe we shouldn't be limited to iPhones. He is happy with his and will probably go iPhone 5S. I'm thinking Galaxy S4.
First thing is, I understand the flexibilty and customisation that Android offers having owned one previously. Any extras that the new iPhone or S4 have that could be of use?
What are other suggestions?
My s4 has been faultless thus far
HTC one is another option, it is the option i went with.
Get your hands on both the samsung and the HTC and have a play with both, the samsung is lighter but feels cheaper/flimsy being all plastic, the HTC is heavier with its metal body but feels a lot nicer/higher quality.
So has my 4s
Which is what's making me curious as to whether the change is all it's cracked up to be.
Apples are a pain in the dick. Eg, the tablet project I am working on at the moment. The have spent months making everything work the easy we need it to on Apple. Took me half a day to get it up and running for my phone.
that being said, if you use your phone for a lot of work emails, the standard iphone mail app is superior to the standard android offering, however for ~$20 you can get touchdown which integrates with exchange very nicely.
If you want to use "work emails" go buy windows. Seriously. I use a windows phone for my on call stuff and its fantastic for outlook syncing.
The best phone currently out is the S4, and its wayyyy cheaper than the icrap 5s.
Did breifly glance at it. Is there much in terms of aftermarket support? Cases, cords docks, etc?
cases and cords yes, but not when compared to iphone offerings for docks, they just use a standard micro USB cable and 3.5mm audio jack rather than plugging onto a dock like the iphones do.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
