Mugabetown - Whoretownin' At It's Worst.
Looks good from pics
If straight might be a good buy. I saw a really nice looking maroon r32 at Skyline Spares. They have just started to pull some bits off. If keen let me know and I'll grab some pics later in week for you and get some info.
Cheap cars aren't always terrible, a few mates have got cars for ridiciliously low low prices and haven't had any dramas
I miss my cheap car :(
Twin turbo supra... Bought it with blown turbos. Replaced them with some second handers... Had the car for twelve months, it took an absolute ass beating (I never even changed the oil in it from when I bought it!)
It then got written off...
I sold the door and rear hatch for more than I paid for the whole car and new turbos... ROFL
