Mugabetown - Whoretownin' At It's Worst.
My parents want me to buy a Mazda and I'm like hmm no. They're like $25000 and they won't let me move out either. I think I need to finally act like a real 18 year old. Starting with friday, getting another piercing, yet another thing they said no too.
NOOOOooooooooooooooooo!!!
second this motion!
Also I was 19 when I got my R33. Dad has always hated it... How unimpressed he was when I bought home the supra a year later and had two "hi-po" cars. Lol
He still hates my R33 and I haven't driven it in 4 years!!!
I don't like manual skylines. I don't wanna brake them
R33 gearbox will take what ever you throw at it if you are making less then 250rwkw...
Mine was making 360rwkw and took flat shifts, clutch kicks and track days. Magnetic sump plug had barely anything on it after 15,000km of abuse like this. It doesn't crunch, doesn't grind, only thing it's shit at is shifting into 5th quickly at high speed (going from 4th to 5th at 6500rpm).
Let it have a slightly slower shift and is happy as!
LOL!!! I got my nose pierced when I was 16 and on holiday with a friend and her mum, I rang them and the response was "your body do what you want" that was actually a sarcastic response, I got it done THEN found out it was a sarcastic response, ahh well... If you are over 18 they can't make you, and if you buy it then the worst they will do it tell you to move out and well since they won't let you know it fixes two problems :)
And I am Melly and I support Ants in supporting said statement...
*high 5*
motion passed.
lol......think we just became more efficient and effective than majority of those pollies in parliament :D
    • Messing around with. Twin kit for. Rb30/26
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
