Mugabetown - Whoretownin' At It's Worst.
Manuals are evil
No
Gladly, yours would no doubt pay a fair bit better than mine
Yes but it can be a shitty job
And slow ;)
No
well see about that uncle Natro
This
Only time an auto should be in a jap car is if its a 2 or 3 speed and used for racing.....
And this
Trannys are good - I love me some Trannys
FYP
Going to be keeping all the associated turbo parts off the 25 skyine incase s*it breaks
Suggestions a for turbos for the dirty? Don't know whether twin or single
Something that's 300 to 350kw max, more than that is fairly unusable without big $$$ tires and borderline too laggy for daily use.
A gt30 with a .82 rear will drive almost as nice as a stock turbo 25, just that it has 300kw instead.
I reckon if you go to the trouble of building a 30/25 then you should choke it up with a small turbo like a GT30.
To get the true benefit of the change I reckon a GT35 or larger is a must.
In saying that Ive never been in a 30/35 running a GT30 variant so not sure how it would drive
Inestment home or residence colin?
Still undecided yet. Its nearly 1k a week rental at the moment so it will be tough to let that go lol. Would still get decent rent if we lived there and rented a few rooms but we dont know yet.
Yeah Ants capt barrel roll is me so wanna get into another one
i had a 35 on mine, too much power for daily duties and enough power to make it about as reliable as a rotary. power came on hard at 3500-4000 and insta wheel spin on anything short of near new 255 semi slicks.
a GT30 with 0.82 would give near on stock turbo spool, but an extra 100kw, a 1.06 rear would tame it down from being so agressive onto boost, but obviously that comes with more lag.
GT30 size turbo is the SMALLEST you can go on the 3L without choking it.
check out the results AL from victoria got with his 3L with GT30, decent power/torque everywhere and the benefit of being able to keep it looking mostly stock if you wanted to, if i was to do my car again. thats the combo i would go for.
Guess mine will be interesting to steer then lol.
I'll have a look for those results. can never look at too many :-)
Congrats Col, I looked up 5 bed townhouses, I think I found the ad. Looks nice! If you are getting the stamp duty concession you need to live in it for 1 year with occupancy starting within one year, and renting out rooms counts as you not occupying it. Something to keep in mind!
eggszachary
these results. i believe the full specs were somewhere in a mountain long thread. but it was from memory it was running a 9:1 comp ratio with some minor head work.
Just realised that i haven't updated my results.
Officially the engine is now out flowing the turbo, but i will not change the combo for anything.
Below is my full tune as it stands now.
The car has been booked in for next week to get the following done:
- Change exhaust and see if any gains are made. Currently i have the more quiet exhaust fitted and would like to compare this result with the Apexi cannon exhaust system i have laying around.
- Play with my cam gears. I still have VVT active, but have modified the std gear to also be adjustable.
- Clean up the afr. Dips too low up in the higher rev range.
- Play with the boost settings, to come on harder on high boost.
- Most important: Find a pair of tyres that will hold traction on the dyno. So far i have tried 4 different pairs of tyres and all have lost traction on full boost at high rpm. I have tried: Hankook K104's, Bridgestone RE55s, Toyo T1R's and another pair of cheap ass tyres from another 33. Anyone know of a good pair of dyno tyres????
    • If your head gasket lifted, you should have seen a coolant pressure spike. There's no need for a copper gasket/fire rings at 30psi. An MLS with perfectly clean/flat mating surfaces should suffice.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
