Mugabetown - Whoretownin' At It's Worst.
Stupid comment of the day goes to... Matt!
You don't need big horsepower. Learn to f**king steer. McFly has 260rwkw, Z32 mike had just shy of 300 rwkw, Cadmoon has 180rwkw, Benno's S13 was running a stock RB20 with factory gear and they would all run after up Nebo, glorious or around LP faster than you.
Coilovers, sway bars, strut brace, decent tyres and learn how to use a clutch and steering wheel properly.
I don't want to hear any one else encouraging p platers to mod their cars in an illegal fashion. Yes, a 30 in a 33 is illegal. The motor wasn't an option and hence would require a blue plate.
Time and time again, the guys who've done it have said that it's not a great idea and have outlined the reasons why. If this doesn't suffice, contact someone else via pm. Colin had a pretty decent 32 and his advice is valid. If you want to play with the big boys, listen to the advice try give. If not, you will be a statistic and create more grief for the community as a whole.
This is a public forum and if you guys don't sort out your act, this page will be closed.
Im not trying nor will be doing anything illegal, I was putting together ideas and asking for a simple opinion I don't wanna cause a big uproar on the page so I'll just leave it at this and agree with you
I'm just doing a project motor. Just looking to do a solid build. Not sure on if it will be going in or not. I'm just doing research and getting ideas from past experience to see what it's like to do the motor side of it
Come time and I'm off my p's and I decide that I want to put it in and I have enough funds to afford it I might go down that ally if I want to try something new with my car
Or I could just rolling shell project it
Yes I acknowledge that me having a turbo on my p plates angers a few and other argue about it and that I shouldn't because of laws
But as I see it. I drive pretty safe I treat the car well I went about it all legal. It's not a flat capper camber hella flush crap thing I want is to look stock and I'm not modding it power wise untill off p plates to avoid a rear examination from tha police
But as I said engine will most likely be sold
The engine is for experience bad learning so I have physical not paper experience
That being said back to whoring I will keep future motor posts out of here
Yeah i dont get the uproar on this at all. The whole point of this place is for the younger guys to ask questions and learn from the people who have done it.
advice isnt gospel either and most of the time people do whatever the f**k they want anyway, i wouldnt stress that hard about it Tony.
Atleast when those questions get asked there is a bit of car talk going on in here even for the briefest of moments.
Threatening to close down the whore thread based on some chatter about a p plater wanting 400kw is a bit much.
  • Like 1
You're right. Its good to see the odd bit of car related talk going on in here.
I also think to generalize all P Platers as certain kind of drivers isnt the way to go about it. I bet there is a lot of P platers out there and even on this forum who are "better" drivers that fully licensed people.
not even for p's just gathering ideas so I can do some research and what not for a conversion when I'm legally allowed to convert into a turbo
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
