Mugabetown - Whoretownin' At It's Worst.
I might pop down late this arvo in a hope it's on the rollers
Yeah.
I don't think it is my coils, I took it for a drive and no issues at all under any load on the factory ones yet when I free rev it around 4k it starts breaking down same as it did with the yellow jackets last night.
I am starting to think it may be over fueling when no boost is being fed in while free revving.
Put the boot into it on the highway and she goes like crazy with no issues exactly the same as it did on the yellow jackets before servicing.
Morning Mangs, got the car up and running on factory coil packs, I took it for a drive but I have not free revved it like I did with the other coil packs.
I will take it for a good drive and see how she goes. May be time to order new coil packs
:) check below
Yeah.
If the only thing moved/disconnected was coil packs to change plugs then it is typically coils. if not, Check leads next, if not then igniter might have a fault.
Just checking with this question, did you change the timing belt/move sensor to do so?
Yeah.
If it's breaking down UNDER LOAD then it will be coils or there abouts... If it's only doing it when free rev the you could have another problem like you said...
Morning all
Morning mate
Sounds like a good plan
Igniter is in the coils, does not look like loom or coils TBH they operate under load and at speed, not plugs either.
Background on the car:
400rwhp r34 gtt
never had an issue with missfire ever
109000K's
only missing at revs while free revving
no issues under load or at max boost (23psi)
Edited by RandomHero83
I've currently in the process of increasing my curling weight from 15kg to 17.5kg. For the last week I've been doing a set consisting of 8 reps on 17.5, 10 reps on 15 then finish with 10 reps on 12.5kg. That's my super set, I take a 1min rest between these sets and do a total of 4 sets.
Can't lift even an apple afterwards
Yep need a straw and a bench to drink water lol
    • I'm not a big fan of the Cometic gaskets either, as above the head and deck need to be like a mirror (can't remember the RA) so Kamieri sounds like a good idea.  FWIW a mate of mine hordes old motor stuff and has some blank unground Nizmo cams for one of these in his supply if random shit if you're interested.
    • This is aem disk setting in aem tuner and still 180 dgree off or ignition on exhaust cycle is it from cas it self as cas seems wouldn’t fit in cam shaft if wrong position and wiring been verified any ideas
    • Oh yeah that would work excellent. Should be the same diff housing & everything. Shoot me a text or call me 260-750-2246 -Cody
    • Oh right, I didn't realise it was your car. Please do! Makes me feel better about mine. I also have a big scrape on the front left bumper where someone presumably used the wall to guide the car into a parking spot  But somehow all the funds go towards mechanical things and the cosmetics stay forever unfinished... Interesting, I don't think I have seen it before. But after seeing @PranK's rusty roofline on the BMW I'd probably leave it alone. Wouldn't want water to get in there.
    • Thanks mate, thought you might know the answer.
