Mugabetown - Whoretownin' At It's Worst.
That place is stupidly expensive. I got new stainless socket caps for the valley cover plus some other M6 and M8 stainless socket caps for $15 from my local bolt shop.
true, but I'm sure they will ahve the sizes that no one else has, and colours
Expensive. Yes. very very high quality good products and a phenomenal online range also yes :yes:
this
or just try Bunnings. You'd be surprised what you can find as quality bolts at very good prices.
Bunnings and Supercheap have a really poor range thats hard to find what you want, and their "high tensile" is very poor at best, be very cautious when using them where strength is required.
having said that, they have been helpful for basic bolts and bits and nicnacks
I also buy from USA military surplus fastener stores - mi spec, any pro will tell you fasteners aren't just fasteners :)
It amazes me how many people use ARP studs without an understanding of why and what makes them better.
My brother in in the airforce in Newcastle. the materials and toys he has on hand are amazing....and that's with a dodgy AU government military budget
Why?? Helping people even in the smallest way is a start :) giving blood is a good way, cos you help save 3 people with as little at 400ml blood. That's all they take. Painless and you get free food
You forget? I can't stand needles (think faint/vomit/me-def-no-likey). Fully appreciate those that can do it, but I definitely am not one for sticking my arm out for a positively terrifying experience :no:
fastersners aren't exactly in the same league as studs though
True that, which is why I separated the two sentences. The studs example was to indicate something easy and tangible that people can relate to as an easy SAU relevant example.
The most important part to the ARP answer is high quality material that has material data testing sheets containing stress diagrams, rolled threads and limited twisting during torqueing that gives a more consistent reading.
And as an engineer Peter knows all of this all too well :D lol
Nuts, bolts, studs and fasteners are actually pretty interesting, so much engineering involved.
My other source http://www.aircraftspruce.com.au/Hardware.asp
almost conned him into building me a Titanium airbox......but then he realised how big the sheet had to be :(
There's a really good friend of mine in Amberley, who's an avionics tech in the RAAF. He got the guys to fabricate an amazing battery holder from Titanium - Best I have ever seen. Those guys know there shizz.
He's a Forum member, but cannot access his old defence email to log on again. Pity, he's an invaluable source of info.
See if you can get the sheet from these guys for him to fabricate http://www.performancemetalsaustralia.com.au/
http-~~-//www.youtube.com/watch?v=ieVDfnUKN9s
Should I fit an rb26/30, rb25/30 or just an rb30 - This clip makes you reconsider :)
as just pure drag car sure.......for street car.........think il go that with that white 1200whp Lambo
Lambo very nice, but this is looking pretty tasty to me at the moment:
http://www.gumtree.com.au/s-ad/parramatta/cars-vans-utes/1994-nissan-skyline-r32-gtr-one-of-a-kind-single-cam-rb30/1029277017
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
