Mugabetown - Whoretownin' At It's Worst.
Morning all. So car just spazed out driving along 60kms 4thgear 3500 revs and all of a sudden the rev gauge starts spazing out, like bouncing back and forward between 0-3500 but the revs didn't change and as well the hicas light was having a slight seizure. Thoughts?
Faulty unit that reads the revs maybe?
Not sure first time its ever done it. Then later it fluttered between 3000-3500 with no actual rev loss to motor. :/ Strange. Didn't play up at happy laps.
sounds like it may be a result from happy Laps.
Also if ur car is spitting flames now and didn't really do so as much could mean its over fueling
Def over fueling you can smell the fuel from the cabin coming in from the window. Gotta find out why next exercise is getting injectors cleaned if not that then have to wait to grt computer done and get tuned
