Mugabetown - Whoretownin' At It's Worst.
Well goodnight bishes...
Taking my nose piercing out, it's so sore and annoying. Yay a normal nose again haha :/
extra breathing hole lol
Nite Kath.
Congrats on the new acquisition too :)
well ok then. I won't participate to LP.
You would be fine around lakeside ants. Just go at a pace you're comfortable with. I did a few lakeside happylaps and had no dramas and last time I checked I had a white 32 gtr
Its Ok. I have survived multiple happy laps at lakeside! White GTR and all.
You have to be a special type of dumb to have an incident at happy laps. Sprint days are another matter however.
Ive never been to Lakeside. Might be worth attending
Do et. I was taunted by lakeside the first couple of times. But I actually prefer it now. Brakes tend to cook less.
thanks mate. I think that can be applied to every track. I'm no superstar racing driver and although I like the idea of flying on a track, I know very I'm totally incompetent, and need to learn how to drive it.
I'm so pissed at myself for missing out at QR. It would of been a great opportunity for me to drive there with you guys.
Can't wait for next track day. I have to get that clutch cooling fan replaced first.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
