Mugabetown - Whoretownin' At It's Worst.
Well goodnight bishes...
Taking my nose piercing out, it's so sore and annoying. Yay a normal nose again haha :/
extra breathing hole lol
Nite Kath.
Congrats on the new acquisition too :)
well ok then. I won't participate to LP.
You would be fine around lakeside ants. Just go at a pace you're comfortable with. I did a few lakeside happylaps and had no dramas and last time I checked I had a white 32 gtr
Its Ok. I have survived multiple happy laps at lakeside! White GTR and all.
You have to be a special type of dumb to have an incident at happy laps. Sprint days are another matter however.
Ive never been to Lakeside. Might be worth attending
Do et. I was taunted by lakeside the first couple of times. But I actually prefer it now. Brakes tend to cook less.
thanks mate. I think that can be applied to every track. I'm no superstar racing driver and although I like the idea of flying on a track, I know very I'm totally incompetent, and need to learn how to drive it.
I'm so pissed at myself for missing out at QR. It would of been a great opportunity for me to drive there with you guys.
Can't wait for next track day. I have to get that clutch cooling fan replaced first.
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
