Mugabetown - Whoretownin' At It's Worst.
no man I don't. Cuz I live on the GC and not western Brisvegas
R I c. I miss mt nebo :( havent even really had a good fang around tambo either since I have moved close (2years) lol
yeah Mt Tambo is a nice drive but is heavily monitored theses days and wayyyy to many accidents which does not help :(
seriously it was sitting at lights when it happen didn't even boost it cause car was still cold.... so from that video you would look for a split ic piping ect?
Sounds very air leaky to me. After looking for air leaks unplug each coil pack. If the idle doesn't change you have found your problem cylinder. Did you say you unplugged the afm and it made no difference? I have had a failed afm and failed wiring to my afm cause issues similar to yours. My money is still on air leak though.
  • Like 1
How hard is a slappa RB30 ?
I now have a metal on metal ticking sound :angry:
I'm thinking I have lost 1 or maybe 2 cylinders, comp test next.
While pulling out the coil packs when running made the car want to stall on all, some didn't change much when plugging back in but did make a change..
PowerFC install stops the car hunting but as the car warmed up and idled dropped it wanted to stall causing it to hunt.
Anyone got a engine crane?
Yeah unplugged AFM then started car on stock ECU ran the same harder to start but did run
PowerFC installed to rules out ecu. Am unplugged wouldn't run. AFM installed it runs but missing..
Did the spray carbie cleaner around hoses and intake gasket.. no notable change..
Who can recommend a Mechanic Southside close to beenleigh ? If only ERD was open still.
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
