Mugabetown - Whoretownin' At It's Worst.
guys i used to work with on oil rigs would work 12 on 1 off ones fully retired at 24 after 7 years on the rigs.
Gallardo in the shed for his troubles
I have a mate the same, He retired this year at 32 after 10 years of work as a mining engineer in a gold mine, at first he was in Kalgoolie then he was in Mauritania, worked 3 weeks got 2 weeks off where they would fly him to wherever he wanted and was on 500k a year for his troubles. He has been more or less everywhere in the world and owns 6 houses outright in Perth and Kalgoolie. He is pretty much just living off rental income for as long as he likes.
mine, silver 33 gtr , white wheels and missing rear wing end caps
I do think i recall seeing it out there. Hard to remember a lot of them. So So many cars. But luckily a lot of ppl's cars arent setup for continuous track use and half the cars where parked in the pits cooling down so the track was never too busy lol
what do you mean you need to upgrade your stock radiator when puting out 3x the factory power? and now you tell me i need to add an oil cooler and possibly a trans cooler too???
madness.
  • Like 1
i was speaking to a former truck driver, has his own house and mostly paid off by his early 20's
he was saying you need to seriously think about how/if you can handle killing someone when you hit them, because its not a case of IF its a case of WHEN. he got out of it not too long after he nearly killed a guy that drove through a stop sign without stopping to check traffic.
madness.
even in stock form the cars still not built for full track use.
one happy laps was enught for me to go back to the drawing board on my car
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
