Mugabetown - Whoretownin' At It's Worst.
Anyone have a magic wand that changes a clutch and timing belt? Not looking forward to this fix haha :P
Did come up with something very dirty to reply but decided best not too haha.
jsut a quick question on the legality of the following
flanged screamer pipe ( so has the ability not to be a screamer piper when the pipe is fitted.
carbon bonnet
carbon boot
carbon bonnet
carbon boot
#1 I presume is legal as long as the screamer isn't fitted on the street.
#2 carbon fibre panels are illegal
second one.
as im new to brissy i have no idea
anyone know of good wheel repair place in the brissy area closer to ipswich the better.
I stress good as the wheels are legit gram light's from way back
Edited by ibrox90
Morning all
Fueling issue is fixed, kinda. I'm getting about 15l/100 but with this cam that's fine :)
lol....I'd be non too impressed if my car drank that much.
My clutch too is in need of replacement, Havent tackled that yet. But the timing belt is relatively simple, as long as you have time and some mechanical knowledge......oh and patience...lots of patience. hope that helps :)
3.6 diff gears and a 2800-3000 stall = bad fuel economy :P
Because skids?
Anyone notice that jackwang in the kippa ring thread? - We are going to make these comments publicly available - It's a public forum what a f**king fool. Labeling us as hoons on our own forum when there is no evidence of such boils my blood.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
