Mugabetown - Whoretownin' At It's Worst.
One of them cheap trickle charger things?
If thats what you are after, buy a cheap solar trickle charger from supercheap, I've got one hardwired in on the parcel shelf of my dads car for 2 years and it hasn't had a flat battery since, just don't park in the shade...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
