Mugabetown - Whoretownin' At It's Worst.
Who has z32's afm's and how on earth did you attach air filtering equipment to them? there seems to be literally no info about how to go about it.
what filter did you get? The filter must be adaptable to 80mm AF meters or else it will never fit!
Still in the office bro.. :(
mate dafaq goin on?
Gettin up early to goto work, stayin late?????
Ask yourself this..............will all my time and effort be rewarded if so...........in what form?
Do not answer that question Tony. Just think about it.
None yet. Don't really want to just bolt a filter onto it sucking in hot air though... but its the last ditch option.
I don't think anyone sells elbows that go on the end to move the pods over a bit in the z32 size, or adapter plates. That being said, adapter plates wouldn't actually be that hard to make
The other option is buying a stock airbox, enlarging the holes 15mm and drilling new bolt holes for the AFM's, as they're in stock location they'll still be flush against the airbox (might be issue with flange protruding past the edges of the airbox face though).
Or i could just buy cheap china spec hard pipe+z32 mounting kit for 300 bucks
mate dafaq goin on?
Thanks for the concern mate. There's actually been a lot going on behind the scenes. Few know. Even fewer understand. Just tried calling and then realised the time. Sorry mate!
Anything that bolts to an RB25DET AFM should also bolt to a Z32 one I think you'll find
all good mate. I was just falling asleep as I could here the phone.
Il call you to catch up.
And morning all
  • Like 1
Morning mate. Really dislike hay fever but that's just a minor inconvenience. Today is going to be a very good day.
thats the way. Got a text message from one of my new clients 10mins ago.......my day will again be interesting to say the least.
Love great starts to the day. Sets everything else in motion.
Last week, had to text a candidate at 5:45 because I had an offer for her. Also messaged another girl at the same time with some other awesome news. Good news = good start to morning = good day.
A custom air box with a neat cold air induction goes a long way I think Pete
exactly why I don't want to just bolt up to the afms directly.
in any case,I think I'm just going to have to wait till I get home to figure out what I'm going to do with them
And nope not me on stage with Taylor, I wouldn't say he was lucky as she now thinks he's a pysco. I'd rather be up there as her lead guitarist :/
them drugs Nick................what I tell you bout them drugs!
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
