Mugabetown - Whoretownin' At It's Worst.
If I end up in the kitty litter at turn 1 I know I've done it wrong lol. Driven it s few times in last two days and they seem fine.
I must admit I tend to just stare at their awesomeness whilst its parked in the garage
Make sure you warm them up before you try a hard press.
One cold morning on my way to work, I had not used the stop pedal since leaving home, then I got an orange light I thought I should stop in a hurry for.
Ended up stopped in the middle of the intersection ;)
Not sure what pads are in em, but they are a race compound I am sure ;)
All adds to the excitement
Well, i never did one from the age of 0 to the age of 18. I was just trying to put emphasis on the "didn't need to do one so didn't do one" thing, guess i was a bit subtle.
you think?
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
