Mugabetown - Whoretownin' At It's Worst.
Almost there......so annoying attempting to do the car around shift work. Mazda threw in one more awesome trick. The turbo has a nice little support underneath (must be because the turbo is so massive *cough*) so I need a 300mm extension bar so I can undo the 12mm bolt holding it in place. The exhaust and front transmission is well placed to make it even harder to manage.
Then all the new stuffs can go on!
Welcome to the world of modding where you will most likely have to buy special tools (or make your own) to carry out your turbo upgrade.
Also,
Is labdirect.com.au one of your direct competitors?
What do you need courage for Pete? Just have a big skull of scotch or something...
No harder job than timing belt right? Or am I missing something?
I'm actually trying to figure out if i need to take off the timing belt completely, or just undo the gears and put the new ones in in place, (assuming the timing belt etc is brand new, that's another thing) or if that's going to mess up the tension on the belt.
Long story short i don't have the tools to remove the harmonic balancer.
Pulley puller, cheap as ;)
Without knowing rb's specifically, I would say it will be faster and easier to pull the belt etc, do the gears and then chuck it back together ;)
Indeed, need to do the full Monty on it, perhaps even drop the radiator out too due to this one being stupidly thick. Not going to do it today though as I want the car tonight+on the weekend, its a Monday job.
Pete I recommend you take the car a good a mech and get it done there.
    • Jax Tyres this Monday morning. Front lifted 15mm Back lifted 12mm Quote1, $175 per tyre + wheel alignment. Quote2, $660 inc wheel alignment. paid $298 for the lot.
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
