Mugabetown - Whoretownin' At It's Worst.
what was wrong with the kit Grego?
Gary's recommended kit includes the following:
Front Eibach Main Springs
Rear Eibach Main Springs
Rear Eibach Helper/Tender Springs
Colil Over Conversion Kits x 4
Front Bilstein Shocks
Rear Bilstein Shocks
Front stabiliser bar adj
Rear stabiliser bar adj
Caster Kit
Front Camber kit
Rear Camber Kit
Front Bump Stops
Rear Bump Stops
Rear Subframe alignment kit
I'd like to hear your thoughts Grego as I was just about to get the funds organised for the above?
Shocks, springs, sway bars and bump stops are good. Everything else i would be going adjustable arms (you can get adjustable arms with rubber bushes rather than spherical bearings). The sub frame alignment kit http://www.whiteline.com.au/product_detail4.php?part_number=KCA349 why would he recommend that rather than just replacing the 20 year old bushes?
Also what about the diff mounts, rear lower control arm bushes, bushes in the rear hubs/uprights and more i can't think of now. There are a lot of parts he has left out.
Hey scotty, calipers are upside down afterall
Yer, thought it was. Ah well ill switch them over next time they need bleeding.. They still work really well
Also, so much zed, so little shed
Holy Zeds Batman...... I like the fact you've got so much love for one type of car. Any chance we will see one of these at the dyno day this weekend or happy laps??
We should have a party at Mikes and see how much of the backyard we can fill with Zeds and Skyrine. If the Zeds win, we but him a beer. If the Skylines win, we put an RB20 in one of his Zeds. :-D
rb20 might at least give more engine room for other mods. May stop the process of taking the engine out of a zed to do an oil change lol
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
