Mugabetown - Whoretownin' At It's Worst.
I thought spots were taken already?
I want to wait a little Grego
Sprints would be awesome but would be a huge step for me and I don't want to jeopardise the car nor anybody else's car because lack / no racing experience
Plus I need to by helmet and whatever else
Baby steps first mate
Typical french man surrendering at the first sign of anything. Talking to you after the cruise you said you would be there.
Sounds like a poor excuse to me :P $100 motorbike helmet
This guy knows poor excuses, also makes a good point that helmets aren't expensive.
Sprints at qr is the place to learn
100% this.
probably. Think anyone can drive better than me
Who really cares, as long as your out there having fun and getting some enjoyment from your car you've spent all this time and money on.
It also gives you a base line to start working from when you start upgrading other parts of the car e.g. hicas locked out, suspension/diff swap etc.
  • Like 1
100% this.
All of this, you have to start somewhere and QR is the best place.
100% this.
I am aware of all of this ^ except for the 'typical Frenchmen surrendering' part I never give up nor surrender to anyone!
There will be plenty of other opportunities to learn with QLD SAU
So what's the real reason for the rush regarding this event?
So what's the true reason behind rush?
We want to see the ant eater on track giving it to some Evos.
Obviously you missed this part
Clearly surrendering
that doesn't answer my question Grego
Also IIRC I'm pretty certain I mentioned to you I wanted to replace my suspension first you seem to have obviously missed that part.
It's pretty simple. I don't feel ready.
If I don't feel ready it's because I'm not ready.
I want to build my confidence slowly and safely.
Not jeopardise everything in one hit because being pushed into something I am not ready for.
I can't be anymore clearer than that and will not be participating to this track day in June.
I will however be happy to spectate to see how it all unfolds
Give me time guys that is all
Just the tip then?
(Out of context phrasing much :rofl: )
Edited by pretX
So bored training to become a lifeguard... When there could be so much more I could be doing
at least you are doing something to help and protect swimmers from drowning
I respect that
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
