Mugabetown - Whoretownin' At It's Worst.
Cheers Ants, Couldnt download on the phone, but works on the computer, damn phone!
Looks like a good list Pete. Few things to consider, Link g4s are a good computer and can be had under a grand if you keep an eye out, for the oil pump see if you can get a hold of billet gears to go in the stock pump, cheap and so far totally bomb proof in mine. what manifold is costing over 2k? :0 the Crank trigger kit costs around $700, you will need an ATI balancer too.
Yeah, all parts are still up in the air.
Wolf is only 1200 bucks for the ECU IIRC, the extra cost is for the actual in line ethanol sensor for the flex setup. But ECU is still very much up in the air.
Oil pump gears might be an idea actually.
Manifold for 2K is one of the sexy sexy Fullrace ones. May not end up going down that route of course, but sexy.
Yeah the full race manifolds are porn. Fecking exxy though especially if you end up getting them coated etc. I saw this one the other day which looks pretty good. Local, twin gate set up already coated etc and much cheaper.
http://www.hioctanedirect.com/index.php?main_page=product_info&cPath=89_90&products_id=2447
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
