Mugabetown - Whoretownin' At It's Worst.
Morning
Hope you get yours back today Scott
Mechanic is working on mine today, sorting front upper arms issue and spherical bearing problem with one of the strut tops.
Also fresh transfer case oil going in and some genuine Nissan coolant now nothing is leaking!
Random question but has anyone purchase black plastic pop rivets before??
Morning
I have faith it will be ready
spotted a red/maroon 32 with gay altezza lights being a f*ckwit on main st wooloongabba this morning.
Thought about putting a D40 bullbar-shaped dent in the back of his car, but I like my navlux too much for that. F*cking tosser.
More details :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
