Mugabetown - Whoretownin' At It's Worst.
Like it, much low down, such Wow
This ^
f**k downlow torque, matter of fact f**k area under the curve, it's all about that pull from 6000-8000 rpm anyway, that's what wins races right.... :ph34r:
This ^
put a t88 on the LS DOOOOOO EEEEETTTT!!!!
Having a look at something on Saturday that might be going into her. You'll have to wait :P
26/30 please with a massive dirty snail
25/30 and 3076 mike?
with the extra capacity a 3076 would be too restrictive on the motor i reckon. I would go a GT35 at a minimum on any 3L RB. WIth a decent cam selection in it you would get superb response
This ^
Dirty Thirties dont like it over 7000rpm lol. Well unless you have stupid amounts of bulk money to help it get there.
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
