Mugabetown - Whoretownin' At It's Worst.
Few photos from today's JapNationals at QR
post-5053-14009167084722_thumb.jpgpost-5053-14009167830964_thumb.jpgshe's stock officer :D
If car gets sold now because I put it up here on SAU, I want 5% commission
post-5053-14009172080722_thumb.jpgthe Impreza WRX boyz
Brap ute??
Sweet R34 GTR
post-5053-140091736194_thumb.jpgdominos sponsored time attack race car
post-5053-14009174525213_thumb.jpgpub Lunch
post-5053-14009175877625_thumb.jpgcasualty in the put lane (think it was a Honda.....I think)
post-5053-14009176614525_thumb.jpgmy little sexy racing queen Emelie
Was a great hot day
wtf has that got to do with it. the car is fine btw.
Wait a minute, why are you getting you're nickers all twisted up?
If you are assuming that I am insinuating that the cause of whatever happened to the car was directly due to tuning, well you would be wrong.
I happen to like Sean and EFI and he did a fantastic tune on my car.
I was just merely confirming that it was the Honda and it happens to be tuned by EFI.
Are we clear!
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
