Mugabetown - Whoretownin' At It's Worst.
I don't even watch the game/follow the game/give a shit but I contributed... I was more interested in a sleep rather than Origin because soccer was on at 2am, which sadly we lost... Although it was a good game! Can't say I was surprised but was good to see how well they played! Maybe 2018 we might go better...
Does this mean we are out of the cup? I don't really follow soccer haha
They still have one game to play but yeah they are out. They played well against stronger teams. Will be interesting how their match against spain goes especially since Cahill is out for the match.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
