Mugabetown - Whoretownin' At It's Worst.
20 Boosts Mike.
At the end of the day the turbos would probably like more, but i don't want to drop the valve spring money, and then might as well do cams... and cam gears, etc.
also, made a map of united E85 locations in-case anyone's interested. Supposedly they're opening one in Ipswich soon to.
  • Like 1
20 Boosts Mike.
Hey Pete,
is your r tuned on Unicorn blood?
Indeed, whole point of the tuning exercise!
Took it for a quick drive up the moutain, feels a whole lot more powerful. Will have to plot it in excel or something to compare it to the old graph.
These results are really making me question what the helll my turbos actually are. 2510s shouldnt make a smidge more power than Petes on 6psi less and on 98.
How much did you pick up from the E85 Pete?
Do suspension, then do E85 but with a flex sensor later
Wise words of wisdom from sir Andy
that is what I was thinking also
I could have afforded both actually but I have been on spending spree of late and ze credit card has to come to nil to keep my levels of satisfication steady - so something has to take a back seat.
I'm keen to also see the comparison
I totally get that, I go to spend on the car car then go naahhhhh I would be happier WITH the money lol
2510's def should not be anywhere near 300kw at 14psi
That's a unique perspective... I don't get it...
I once was unlike that too, I guess it comes from being an old bastard!
Yeah, I suspect when they were overhauled they copped a high flowing also. I usually see 300rwkw at 20psi or more from others using 2510s. I was never able to run any timing either. Will be interesting to see what they are really capable of. Edited by Bunta
if that's the case those turbos are going to be EPIC to say the least
40hp, with 4psi more. but limited by the valve springs.
    • If the forester is anything like our old 2007 GTB Liberty, I could near on run ling Long's and "rate them", as no matter what, it just hung to the road, even when abusing it in a hard launch in the wet, or throwing it at corners.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
