Mugabetown - Whoretownin' At It's Worst.
except for Nick - he truly is a commodore wannabe but then again you do have commodore blue on your R31 too
Suck my left nut mr ants, amazing what you find when u dig through threads lol
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
