Mugabetown - Whoretownin' At It's Worst.
Also, hopefully got my zed sorted. Looks like it was possibly a corrupt table in the ecu. Wiped the tune and started again and it seems to be ok.
Needs some more kms to be sure, then a full tune.
Ecu running Windows ME?
And cause mine was a type s lucky me got Hicas on my NA :dry:
Yeah, lucky hahaha
hicas is f**king shit. Don't realise how shit it is until you delete it
Edited by MagicMikeZ32
Soon mine will be gone, yippee.... Martin asked me if it pisses me off, after almost 8 years of having my car I figure I am just used to it. I didn't drive Zanes enough before he got rid of it to notice the difference too much.
You notice it when it suddenly activates for the first time in over 2 years under brakes into a tight corner. If it is broke fully broke don't fix it?
oooh I know that feeling. Almost hugged a concrete barrier when mine decided to say hello
Failed safety cert =/
Caster arms and drivers seat
Someone sell me parts
I'm pulling out my factory castor arms this weekend and I have a manky/slightly torn 33 drivers seat. You can borrow both but I want my castor arms back.
such a sweet mouse aint he?
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
